When I try to boot from the Win2K or WinXP CD, it always get stuck whlie the setup files are being loaded.
Win98SE is installed on this system, so I also have tried to upgrade WinXP from there, but it also freezes.
Is it the problem with the chipset? Or something?
I have changed the HDD cable (because it gives me error after I inproperly shut down the Windows, saying that there's a bad clustor. But I did a disk scann on another computer, it seems to be fine).
I also changed the power supply. I don't think that is the problem though.
I have ran the Prime95 to test the RAM and the CPU, the results were good.
I took all of the cards out except video card and test it, no luck.
So, what's up with this?
By the way, the mobo also has the latest BIOS updated.
