win2k volume control missing
crazyjoekuta
any ideas why it isn't in the bottom right corner (forgot the name)?
i updated my abit kt7-r bios, reformatted, and reinstalled win2k and now it's missing.
Go to:
Control Panel - > Sound and Multimedia
somewhere near the bottom, there should be a checkbox "display volume control on the taskbar"
Eric
START -> SETTINGS -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA
check the box that says "Show volume control on the taskbar"
I had the same problem in win98 se, and there was no sound either. Still can't figure out the cause of the problem, but restarting is a temp resolution.
