I have Win2K Pro w/SP1 installed on a system with the following:
ASUS A7V (no on board sound) w/ AMD Thunderbird 900 mhz
Diamon MX300 PCI soundcard (Aureal Vortex 2)
256 Mbs PC133
10 gig Maxtor HD
GeForce video card
Netgear 10/100 NIC
When I first start up the OS the sound will work once then goes away and won't work again until I restart. For example if I start up Winamp and hit play it will play sound correctly but if I hit stop and then play again the sound is gone. Same thing with windows sounds. The first sound file (appearently of any type) I run will issue sound. Everything after that is silence. This is the strangest of problems. I am using the driver set for my sound card that comes with Win2k and there are no hardware conflicts that I can find anywhere. I use a swapable HD and when I swap out my Win2K HD for my Win98SE HD all sound works perfectly fine under Win98SE. Does anyone know what the issue is here?
Thanks for any help you can provide,
Dane R. Vinson
256 Mbs PC133
10 gig Maxtor HD
GeForce video card
Netgear 10/100 NIC
Dane R. Vinson
