Win2K shutdown problem!!!help please
tgi
When try to shutdown my computer I see the following;
-Now it's safe to turn off your computer-
or something like that.
It hangs there and I had to turn it off with the button behind the tower.
any suggestions?
is that about any wav file that Win2K uses during shutdown or what?
If you have Win2k Server installed, that is normal, when you see the "Safe to turn your comp off" screen just depress the on/off button and hold it in for 10 sec or so.
If you have Win2k Pro installed you need to enable "APM" Right Click on Desktop, Properties, Screen Saver, Power. You should see a "APM" tab click on it and enable it, it should then shutdown normaly.
Hope this helps!
Bigguy1
