Hi all,
i bought an 80GB drive last weekend and installed it this morning. Used the disk-setup utility that came with the box(WD800) to format and it worked fine Then i started to install Win2k Pro on that drive(my older drive has win98, thought i'd keep it separate until i was sure the win2k install works properly, since its the first time i'm installing it). Went through all the initial install screens, until it came to the screen asking me which partition(drive) to install it on. I selected D:, then selected to reformat it to NTFS. The re-format started, but it shows the disk size to be 76130MB, with 76080 MB available. My questions:
* I'm wondering where the remaining 4Gb is gone. or is this normal?
* would also appreciate if you could advice if its a good idea to keep the disk as one huge partition, or if i should break it up into smaller partitions? If i do partition it, can i re-format/mess around with one partition without affecting the others( so i can separate the OS stuff from data without affecting each other)?
thanks, much
rykyc
thanks, much
rykyc
