Win2k Dial-up problem
<< Yeah, go to your Control Panel, add a new connection under "network and dialup connections." >>
Ah, you see, that is the problem. I had two connections all set up, and everything was working fine. But after the last restart of the system (I didn't change anything), the
connections weren't visible any more. They are still there, I can connect through IE6 connection dialog, but I can't see the from Network folder. When I connect, the dial-up icon
in the tray doesn't show up anymore. If I try to make a new connection, everything goes fine, but that connection is also not visible from Network folder... I think I will have to
reinstall complete dial-up section... or Win2k... 🙁
