Win2000 Pro and Half-Life...HELP!!
wnied
I am (trying) to run windows 2000 Professional and Half lifes TFC and keep having problems with extreme slowdown. Basically it amounts to me having a ping of 1500-2000 on EVERY server I enter. The video drivers are the Voodoo5 5500 1.04 version. The settings are on Direct3D, and default. Everytime I try to enter a TFC game, its so slow its like running the game on a Pentium 166. Are there other drivers I should be using for my VooDoo5 5500 pci? When I run the same games with my Millennium setup, it runs great. Sub 100 pings and all. But with the win2k drivers...My ping sucks horribly.
Any Helps greatly appreciated!
wnied
Ok listin Voodoo's can work with DX and OpenGL
since you have an Voodoo I suggest to use OpenGL! I had some prolbmes with it too and I found out that it was DirectX for some strange reason
update your OpenGL. if you do not wish to change and goto openGL then update your DX to DX8a
(DX8a Recently came out)
