Win2000 drive letter problem..
TheVrolok
24,254
4,092
I just recently put together a system and installed 2k.. BUT something seems to have gone wrong. My drive letters are out of order. My backup drive (20 gig) is now C, my system drive (120 gig) is now F, with my DVD ROM and RW in between at D, and E. Drive management will let me change all my drives but F, my system drive, of course.. but this will drive me NUTS... I need my system drive to be C.. is there a way I can force it to change? Thanks in advance. :)
NogginBoink
5,322
If the system was installed with F: being the system drive, you'll break all kinds of things if you change it.
If it was originally C: and you added drives and now it shows as F:, you can edit mounteddevices in the registry to change it. (Searck the KB.)
Panther505
560
Reinstall? The problem is that you had a partitioned, formatted drive installed when you began the installer. If you remember in the setup it showed that drive as C: (shouda been a hint). The BEST way to get it to C:? Reinstall with NO OTHER formatted drives attached. Then you will be straight
Agamar
Too true...I have been down this road before...It is a real son of a gun.
Palek
937
Heh, my Win2k partition is J: (I am a partitioning FREAK :)) and it doesn't bug me now, but naturally I was going crazy when I could not figure out why the install chose J: as the drive letter. Too much stuff on it now to do a reinstall, but when/if I move on to WinXP, I will remember the good advice. Thanks to TheVrolok for the good question and to the others for the great answers!
digitalman
167
problem is if you just reinstall, i am pretty sure that the drive letter will stay the same. this happened to me once and i went crazy trying to figure out how to switch the system drive back to c:\. you can try using partition magic. i forget the name of it, but there is an app included with partition magic that will change drive letters globially on your system. this isn't on the PM boot disks, only the full windows software.
since i wasn't aware of this app when i had the problem, what i ended up doing was backing up my stuff and just doing a clean install. it was a real pain, but things ran better once it was done and i stopped freaking out once f:\ was returned to the comfort of c:\
in retrospect, it is amazing how conditioned we get in windows about which drive is labeled by a specific letter. one of the clients that i do work for freaked out when after doing a clean install of XP his zip drive, dvd drive and cd-rw all changed letters. I chuckled a bit to myself as i watched him rip down the sticky note on his monitor that was his legend:
c:\ main hard drive
d:\ dvd
e:\ cd-rw
f:\ zip drive
and then he made a new one and put it back where the old one was. He told me that he had just gotten used to where the drives were. you can only image his frustration when i told him i could change them back.
i think that was one of the things that i had to get used to on my powerbook.... no drive letters - just drive names. After a little adjusting, i realized that it totally makes sense. plus if you don't have a cd in the drive, it doesn't appear. when my mother-in-law made the switch, that was one of those things that really took her for a head spin.
