Hello, I'm new to the boards and normally I don't make threads unless I'm really really confused and so I am.. I Just reverted back to windows 2000, installed the 128-bit encryption addon and all the critical updates and stuff.
Whenever I try to load an ActiveX (I think) my browser crashes and just gives me this message: http://img154.exs.cx/my.php?loc=img154&image=untitled5lv.png
Now, this happens when i go to windows update, try to online virus scan and all that. Ive used norton to scan for viruses and run ad-aware to remove all spyware so I dont think thats the problem. Ive also upgraded to IE6, and back and nothing seems to be working.
I restored my internet settings to default as well as changing my internet security settings for activex to always be displayed. Im not even sure if its active X or something to do with a proxy, if it has something to do with a proxy the problem might be that Im using ENTERNET 300 for my DSL since im using windows 2000 its required. If you can leave feedback on how I may resolve this issue it would be deeply appreciated, thank you.
edit: this also crashes my outlook express when i try to open it giving the same error, which leads me to believe it might have something to do with my enternet.
