Question Win10, VS 2010 problem
IBMJunkman
966
430
Win10, VS 2010. Working website on local IIS. Developed and tested on this PC. Made a small change to a project. Built fine. Trying to publish to local IIS. Get this error:
Error 1 Web deployment task failed. (There was an error reading IIS configuration schema from 'C:\WINDOWS\system32\inetsrv\config\schema\'.)
I can view the folder using Windows Explorer. I am blocked when trying ZTreeWin in non-admin mode. The file IIS_schema.xml was last modifed 3/2021.
I have no idea what the problem is. Help!
19,219
IBMJunkman
966
430
I have uninstalled Web Deployment Tool version 1.1.0618. I have installed Microsoft Web Deploy 3.6 version 10.0.1973. No change.
All done while logged into the Administrator account.
C:\WINDOWS\system32\inetsrv\config\schema\ is marked ReadOnly and the Admin account cannot change it.
IBMJunkman
966
430
Don't have access to VS 2012. And the Azure thing says it can't find the product I am trying to install.
19,219
All I can think of is, install the Windows version in VM that existed when VS2010 came out. Build your project inside the VM and publish it from there.
