I have two external drives I rotate as backup drives. Both are encrypted with BitLocker, and both worked fine in Windows 8.1. Since the upgrade to Windows 10 Pro, I can't access either one.
In "This PC," they both appear as a drive, they have the unlocked padlock and note as a "BitLocker" drive (the unlocked padlock implies the system remembered the correct password; it was stored in Win 8.1 before the upgrade). I can even change the BitLocker password without a problem; drive shows the unlocked icon on reconnecting.
Double clicking gives a "The parameter is incorrect" error. Disk Management shows the correct size for the disk and partition, says "Healthy." But the File System lists as "Unknown (BitLocker Encrypted)." Ran chkdsk on both from cmd, with no errors reported.
Kinda at a loss for what to do next other than wipe the drives and start over. Help please?
