Originally posted by: LiLithTecH
The only other alternative would be to disable the Highpoint controller
in the BIOS, provided that he is not using that as the boot drive.
The HPT366 controller cannot be disabled on a Soyo 6BA+IV (had one of those for years, loved it, but it died an unfortunate and tragically sudden death
Have you tried using the Win2k drivers? It's been some time, but I believe that worked for me. You get an error about the drivers not being "certified" but you just go by that
edit: doh! should have read all the posts. When I installed XP on that rig, I did a full install. The advice of others, to put the boot drive on the ATA/33 controller, is probably your best option. Make sure your dad completes the entire install with the OS completely setup and then installs the HPT366 drivers
before he moves the drive back to the HPT366 controller.
