Win XP fax printer problems
KaGee
:disgust: Since installing my new mobo (Abit NF-7S), modem (Zoom V.92 PCI) and a repair installation of XP, I cannot fax.
Anyone here have any experience with this before I go into all the gory details??
Is the fax function installed? By default, it's not installed. You have to manually install it from the cd (add/remove programs in the control panel, go to add/remove windows components). If you did a reinstallation of XP, it's probably not installed.
Yes... installed and reinstalled..... several times.
But, good news... I just finished applying SP1 and now the fax printer connects.
Go Figure!
Still don't know why it wouldn't connect before. Worked fine with old MOBO.
