Win XP and Half Life; Problems?!?
guamboy
21
I've had XP installed for almost two weeks now, and except for the mind set of using 98SE, I've very happy with it. My install of Half Life (Blue Shift) went normal, but everytime I try to start, the screen goes black for two seconds then my desktop comes up. I've heard mixed reviews on detonator drivers (which ver.) so I haven't installed any of them. Besides, I always assumed the det. drvr. were more for performance than operating.
abit kt7a
asus 7700
256 kingston value ram
tb santa cruz sound card
ibm 60 ser. 40 gig
lite on dvd drive
tdk veloCd burner
seimens net card
pinacle(?) firewire card
3com modem
Mem
21,476
13
I think I know your problem, you are using the default WinXP Nvidia drivers that come on the WinXP CD? Well they don`t support OpenGL and I presume you are trying to run HL in OpenGL mode rather the D3D so you need to upgrade to newer Nvidia drivers for XP which fully support OpenGL the best at the moment IMHO are 23.12 drivers which you can get and download by clicking on Windows update in WinXP.
You may want to download Windows 2000/XP NVidia Refresh Rate Fix as well which fixes the 60hz problem in OpenGL,install it after ok.
Btw you should have the latest drivers for your Santa Cruz as well,if you still get problems try Windows 98 compatiability mode.
guamboy
21
Okay, I downloaded the patch(?) and I downloaded nvidia 2.3.1.2 from MS and still have no luck running Blue Shift. I'm not sure what to try next, any ideas??
Wuzup101
2,334
37
You could try www.guru3d.com and just download some dets until they work (or you run out of dets). Also try the det destroyer to remove everything from your registry between changes. Half life is completely compatable w/ WinXP (I have half life, CS, and opp force) and all of them work fine. I recently had a frame rate problem but that was fixed, and it was b/c i'm an *** and wasn't XP's fualt.
aka1nas
4,335
Do any of you guys get a problem when you alt-tab out of CS in XP and when you alt-tab back in, you only get a black screen? I haven't found a work around for this yet. I have tried using several Nvidia driver versions(except 23.11, it has never worked on my comp w/o BSOD whenever I boot up.)
TheJTrain
665
I'm running XP and have a wierd problem with Half-life. It runs ok, and you can load a game when you first start it, but if you ESC to the menu and try to load another (rather than an in-game quickload), when it loads the game, all you get is the Half-Life background screen (with the version number on it) and the actual game sounds. I have to exit the game to the desktop then start it up again. Anybody else seen this? (Yes, I have the latest patch)
Jason
DaLeroy
1,406
<< I'm running XP and have a wierd problem with Half-life. It runs ok, and you can load a game when you first start it, but if you ESC to the menu and try to load another (rather than an in-game quickload), when it loads the game, all you get is the Half-Life background screen (with the version number on it) and the actual game sounds. I have to exit the game to the desktop then start it up again. Anybody else seen this? (Yes, I have the latest patch)
Jason
Yeah, I have this on one of my machines only. Running XP, and if you press ESC or quit a game, and try to resume, or start a new one, you hear sounds, but the menu stays up, doesn't switch to the game. If I go back to the main menu, it works tho ....
