win 98 problem
aces170
46
i have installed win98 on my pc.when i start my pc it starts properly
for first 2-3 times.after sometime i restart it goes to the startup
logo of win98 and then either restarts or tells me
Windows protection fault.pls restart your computer.
i tried with a couple of display cards still i face the same problem.
i tried removing my ram and placing it again but no use.
howdyduty
490
We will need more details about the hardware and configuration.
You may want to try to reinstall.
MichaelD
31,528
You obviously have old hardware as well as an old operating system. No offense.
Mechanical and Electrical parts DO wear out over time.
It's time.
You were dreading someone saying this, right? ;) But it's time.
Time to buy or BUILD a new computer.
Could we get Win98 working for you again? IMO, 75% says NO. B/C of the chance of your hardware being old and therefore, possibly failing.
As of 13 August 2004, it's just not worth fixing a Windows98-based PC anymore (I.E. a PC with a Win98 OS and hardware from that era....the PC is worth about $20.....if that much)
These days, PCs are cheap and WinXP Pro can be found for $150 or less.
Make the jump; you won't be sorry. Win98 was such an inferior operating system in many aspects. Change now: it's the perfect time.
aces170
46
the thing that pc is for office use only and it does not require any better hardware.that is why i am trying to fix it.
redbeard1
3,006
Is the cpu being cooled properly? Overclocking? Is the voltage and multiplier set correctly if it is not detected automatically. You might try this memory tester also.
Memtest86+
Gurck
Banned
Mar 16, 2004
12,963
^ good advice. Memory's my first guess as well. After that a reinstall might be a good idea; I remember '98 used to thrive on frequent OS reinstalls (ie. it sucked :p)
