win 98 error msg - need help
bKo
57
"cannot find a device file that may be needed to run windows or a windows aplication."
"the windows registry or system.ini file refres to this device file, but the device file no longer exists"
"if you deleted this file on purpose, try unistalling the associated aplication using its unistaller setup program"
"vnetbios.vxd"
- i get that msg when ever i boot up my cpu.....
is there a way to fix it>???
would reinstallin windows help??
5mudge
59
You probably had a program installed at one time that referenced that file, but after uninstalling the program a registry key was never removed (or a reference to the file in the system.ini file, but that is less likely).
Run regedit, backup your registry, then to a search for "vnetbios.vxd". Delete those keys where this shows up (you backed up your registry, right?), and reboot. You should be fine.
If you're really worried about hosing your box, backup your data as well.
Doomer
3,721
Uninstall then reinstall all network components. If you're not on a network then just uninstall all network components.
