Win 98 box won't auto power off after shutting down
RickH
784
Help!! I have a W98SE machine that will not auto power off after shutting down Windows, you need to push the power button like on an AT motherboard computer. I have looked in the BIOS and can't find anything. It's a dual slot 1 Supermicro board. Thanks. R
Epyon9283
201
I havent used 98 in quite some time but is APM enabled in the OS?(note that I might be really wrong about that)
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
Does it give the prompt "It is now safe to turn off your computer", or does it just hang? Do you have ACPI turned on in bios? Does Win98 have the proper board drivers installed? Have you downloaded all the updates? Are you running dual processors with a single processor OS, or are you only running a single processor on that board? Please include your system specs and hardware installed.
RickH
784
It gives the message "It is now safe to turn off your computer". It is a W2K pro box not W98 (sorry old guy in action) with 2 processors, SCSI drives. It was on an instrument so we did not want it to auto shut off. I am not at the machine now, so I will check the ACPI again in the BIOS on Monday. Thanks. R
Dre
2,247
4
Sounds like you have ACPI disabled in windows. You can find this option in control panel under power.
mastertech01
Nov 13, 1999
11,875
282
If you had ACPI turned off, it probably loaded Win2k as an MPS multiprocessor system HAL, and you may need to change the driver for the system once you reactivate ACPI. It should say in device manager under computer "ACPI multiprocessor computer". Sometimes it really messes things up and you may need to reinstall Win2k to get the proper system hardware abstract layer installed. Good luck
Iron Woode
31,335
12,840
Just check that APM is checked off under power management. If it isn't then do so. Let us know.
