Win 2K problem
linux
7
i have installed 2 ethernet card in my computer. both of them are D-
Link. i just wondering how can i use one of them to connect to the
ADSL and the other is connecting to the hub? the one connect to the
ADSL modem works fine but the one with the cross-over cable to
connect to the hub is not working. is my steps wrong? should i use
all parallel cable instead of that cross-over cable?
thx!!
trend
603
use parralel cable if you are using a hub.
and adsl are expensive !@!!!!!!!!! they get 1.5 up and down, right?
