Win 2K hal.dll problem
IppatsuMan
Hi
My problemis : I have the blue screen pop in Win2K after the session start , it says : IRQL_LESS_OR_EQUAL regarding the file hal.dll . ACPI problem I think , but what can I do ?
System
s2462 UNG Mobo
2x1,2 Ghz Palomino
1Go Ram
Gloria DCC Video card
2X60 Go IBM SCSI HD
Sound Blaster Live
Thanks for any reply 🙂
ithink this is due to ACPI. It seems that your system may have ACPI disabled. HAL is not meant to be used by Win2k, but can be during installation, so that you can change IRQ's and the like in device manager. I would try re-installing win2k over the top of you current installation.
dave
