Win 2000 pro and HP deskjet problem
Quaker
38
When i try to print it acts like its going to then does nothing. Checked for drivers but there are none it says the drivers are on the win 2000 cd. and those are loaded but for some reason it just won't do anything. I know it is all hooked up right because when i can still print in win 98 but when i boot to 2000 it doesn't.. The printer is a Hewlet Packard deskjet 812c.. Any ideas..... plz help me... thx
Pederv
1,903
Start>Settings>Printers
Is it listed? Can you do a test page? Have you gone through the printer troubleshooter?
Quaker
38
Nope can't do a test page either.... gonna have to reboot so i can go into 2k and tell ya the error.. It acts as tho it is goin to print.. ie ... opens dialog box print icon goes to taskbar and shows it as printing but it does nothing. ok it just says There was an error found when printing the document "test page" to lpt1:. Do you want to retry or cancel this job.... and it takes like 2 minutes before it gives this error.
Quaker
38
Ok got it working. Had to install my scanner first since it runs off the ltp port and printer just plugs into the scanner. sounds simple enough but problem was in win 98 it didn't matter if the scanner was installed or not it would still let the information pass through it so it could print.
