A tential problem you're having has to do with your Highpoint ATA-100 Controller. The manual for your motherboard lists a specific routine that MUST be adhered to when installing Windows 2000: (Quoting from the manual now)
"Before you start to install Windows 2000, you have to create a driver disk from the driver CD. You can copy the HPT370 UDMA Controller driver files from the driver cd that comes with this motherboard. The path for the HPT370 UDMA Controller driver files is:
"X :\INF\VKB\HPoint\Floppy" (X is your CD-ROM)
Please note two things before you copy the driver files to diskette. Firstly, the driver files must be copied to the root directory of the diskette. Secondly, you have to set your system to "Show all files". Otherwise, you will be unable to copy some important system files to diskette.
Installing Windows 2000 from a CD:
1. Press the "F6" key when Windows 2000 displays the following message:
"Setup is inspecting your computer systems hardware". This will display a new setup screen, then prompt you to press the "S" key to add a device. (S=Specify Additional Device)
2. Press S, and insert the HPT370 UDMA Controller driver diskette. Press Enter when prompted and allow Windows 2000 to install the HPT370 UDMA Controller Drivers.
3. Please use the UP or DOWN arrow key to move the highlight to the mass storage device you want and press {ENTER}
4. Win2000 will continue and complete the installation procedure."
Now, after you do that, I'd try to continue the Win2000 installation routine. If it STILL bluescreens afterwards, I'd do the following (according to some others who have this or similar boards and problems installing Windows 2000):
From what I can gather on the net, people who have this and similar boards with your installation problem have gotten around it by disabling the onboard-sound in the bios, then re-enabling it after installation is complete. You may need to download win2k drivers for the onboard sound at that point.
I disagree with the person who claims that Win2k will not install correctly with ACPI disabled. That's not correct. I've run it that way myself, without problem. But my point for now is to try disabling the onboard sound first in the bios. It's under the Integrated Peripherals heading. Once there, go to the "Multi-Media" heading. Choose "Disable", then try reinstalling Win2K.
I don't think your issues have anything to do with ACPI, by the way.
