I have installed the updated HP software drivers from HP for the Scanjet 5200C.I then shutdown the system, connected the Serial cable and turned on the scanner and rebooted.
My problem is that the computer will not reboot, it goes through the motions all the way to a blue screen then shuts down and reboots and continues to reboot indefinetly.
I have also set the Printer Port to "Use any interrupt assigned to the port"
After loading the software I noticed in Device Manager that SCSI/RAID Host Controller developed a yellow exclamation mark.
Any ideas on getting my system up and running would be much appreciated.
Thank You
Regards
Kiwiandco
Thank You
Regards
Kiwiandco
