Win 2000-Belkin Raid Card-Hard Drive Problems- Help
pablo1234
Working System:
ADM TBird 1100
Asus A7Pro MB
512Mb PC133
Linksys 10/100 LAN card : Slot 5
GForce 3 32Mb AGP Vidio Card
Maxtor 40GB 6E040L0 7200RPM Primary Master
Western Digital 40GB WD400BB-00AUA1 Primary Slave
Asus CRW-4012A Secondary Master
Belkin - Silicon Image 680U ATA 133/Raid PCI slot 2
Windows 2000 A Server Service pack 4
I have installed the drivers for the Raid card and my system runs fine.
I hook up a Quantum Fireball ST 4.6GB and start my computer. Everything is fine. the hard drive is detected buy the cards BIOS and By Win 2000. No problom.
I shut down the system and remove the small drive. Connect A Maxtor 40GB 6E040L0 7200RPM Drive and reboot. The Raid BIOS detects the drive. windows starts. SiICfg writes to the log file:
01-October-2003 18:58.21 Error - Device remove
The secondary master on adapter 0, Maxtor 6E040L0, was removed.
The drive dos not show up in the MMC Disk Manegment.
I shut down and unplug the drive and put the Quantum Fireball ST 4.6GB in again and restart. Everything works.
I change it back to the Maxtor 6E040L0 and change the drive to CS. The Raid BIOS detects the drive. windows starts. SiICfg writes to the log file:
I shut down and remove the drive and place an IBM-DPTA-372050 20 GB drive in its place. I restart. The drive is detected buy the Raid BIOS. windows starts. SiICfg writes to the log file:
01-October-2003 19:07.41 Error - Device remove
The primary master on adapter 0, IBM-DPTA-372050, was removed.
I change the drive to cable select and get the same thing.
I try a MAXTOR 6L020J1-
The primary master on adapter 0, MAXTOR 6L020J1, was removed.
I put the Quantum Fireball ST 4.6GB in and every thing is normal. What's uh the deal.
Hear is a report the Silicon Image Utility prints:
SiICfg Configuration Information. 01-October-2003 19:55.14
SiICfg Version 1, 1, 0, 15
Computer Information -
Name RTSPC
Windows NT 5.0
Service Pack 4
Adapter 0 Information -
Chip Model PCI-680
Chip Revision 0002
Chip Type RAID
Driver Status 0
Major Version 1
Minor Version 1
File Version 1, 0, 1, 6
File Date Tue May 07 14:10:42 2002
PCI IRQ 9
PCI Bus Number 0
PCI Device Number 11
Primary Channel Information -
IDE Base Address A400
Alt Base Address A002
DMA Base Address 9000
80 Pin Cable Yes
Master Device Information -
Master Not Present!!!
Slave Device Information -
Slave Not Present!!!
Secondary Channel Information -
IDE Base Address 9800
Alt Base Address 9402
DMA Base Address 9008
80 Pin Cable Yes
Device Type Disk
Hot Spare No
Model Number QUANTUM FIREBALL ST4.3A
Firmware Version A0F.0800
Serial Number 854735195378
Current Mode MDMA 2
Supported Modes UDMA 2,UDMA 1,UDMA 0,MDMA 2,MDMA 1,MDMA 0,PIO 4,PIO 3,PIO 2,PIO 1,PIO 0,
Bytes\Interrupt N/A
Media Type Nonremovable
ATA Version ATA-3
SMART Support Yes
SMART Enabled No
SMART Status N/A
Look-ahead Disabled
Write Cache Disabled
Capacity 4110 MB
Indentify Data -
0000 045a 3a00 0000 0009 7e00 0200 003f 0000
0008 0000 5154 3538 3734 3533 3931 3335 3837
0016 2020 2020 2020 2020 0003 00a3 0004 3041
0024 2e46 3830 3030 5551 4e41 5554 204d 4946
0032 4552 4142 4c4c 5320 3454 332e 2041 2020
0040 2020 2020 2020 2020 2020 2020 2020 8010
0048 0000 0f00 0000 0200 0200 0007 3a00 0009
0056 003f 7600 0080 0110 7600 0080 0007 0407
0064 0003 0078 0078 0078 0078 0000 0000 0000
0072 0000 0000 0000 0000 0000 0000 0000 0000
0080 000e 0000 0009 4000 0000 0000 0000 0000
0088 0007 0000 0000 0000 0000 0000 0000 0000
0096 0000 0000 0000 0000 0000 0000 0000 0000
0104 0000 0000 0000 0000 0000 0000 0000 0000
0112 0000 0000 0000 0000 0000 0000 0000 0000
0120 0000 0000 0000 0000 0000 0000 0000 0000
0128 0000 0000 0000 0000 0000 0000 0000 0000
0136 0000 0000 0000 0000 0000 0000 0000 0000
0144 0000 0000 0000 0000 0000 0000 0000 0000
0152 0000 0000 0000 0000 0000 0000 0000 0000
0160 0000 0000 0000 0000 0000 0000 0000 0000
0168 0000 0000 0000 0000 0000 0000 0000 0000
0176 0000 0000 0000 0000 0000 0000 0000 0000
0184 0000 0000 0000 0000 0000 0000 0000 0000
0192 0000 0000 0000 0000 0000 0000 0000 0000
0200 0000 0000 0000 0000 0000 0000 0000 0000
0208 0000 0000 0000 0000 0000 0000 0000 0000
0216 0000 0000 0000 0000 0000 0000 0000 0000
0224 0000 0000 0000 0000 0000 0000 0000 0000
0232 0000 0000 0000 0000 0000 0000 0000 0000
0240 0000 0000 0000 0000 0000 0000 0000 0000
0248 0000 0000 0000 0000 0000 0000 0000 0000
RIO information -
Major revision 1
Minor revision 1
Array conflicts No
Number of sets 0
