Win 10 Desktop Background Slideshow Timing Problem
LPCTech
679
93
86
In windows 10 there is an option to use a folder filled with pictures as your background, it gives options for how often to change the background, 1min, 10 min, 30 min, an hour, a day etc. But here is the issue I'm having:
I have the slideshow set to my folder filled with backgrounds and the backgrounds change, no problem, I have it set to change every 30 minutes, BUT it doesn't change every 30 minutes. It changes whenever the hell it wants to. Yeah, weird.
So I will have a background up for 5 min and it will change or it can be the same background for 2 hours and then change. There seems to be no rhyme or reason to the timing even though I have it set to change every 30 minutes.
Anyone ever see this before? Any way to make it...you know simply change every 30 min like its supposed to? I am stumped, you would think an OS in 2016 could keep track of one task to change the background every 30 min. But no.
If anyone has any info about this or a way to fix I'd appreciate the help.
