- Aug 26, 2014
- 1,792
- 508
- 136
This is a question that's been popping into my mind from time to time recently. As process technology improves and hot transistors are concentrated into ever smaller areas, we're seeing clear signs that a simple copper IHS as a protector between desktop CPUs and a HSF/water block is becoming a limitation. As I'm (barely) old enough to rememeber the days of bare AMD CPUs, third-party CPU shims and cracked dice in the early 2000s, I doubt we'll be returning to non-IHS packaging any time soon for the desktop/DIY crowd. Laptops already go this route, but that's a far more controlled environment.
As such, I'm wondering if we'll see high-end SKUs where the IHS is a tiny vapor chamber. Of course this would be a significant cost increase from the cast/pressed copper lids used today, but as 120W+ chips shrink towards/below 200mm2, might it become a necessity?
Of course, Intel seems to be going the opposite direction, with lower-end SKUs cheaping out on cooling in any way they can, making this work by improving power efficiency rather than performance. Above 60-90W, though, this seems like it would backfire significantly, as shown by the prevalence and results of delidding chips like the 7700K.
On the other hand, higher-end chips have the IHS soldered on. Would this even be possible with a vapor chamber? Not only would it require far more power (again, increasing costs) to heat up to the temperature needed to melt the solder (around 170C for the Ryzen series, according to Der8auer), but could a vapor chamber survive temperatures in that range without taking damage? Would this require manufacturers to adopt "liquid metal" TIM?
Also, might we see third-party vapor chamber IHSes marketed to delidders? Would this at all be possible without breaking cooler compatibility due to the added thickness? And what about mounting pressure? LGA CPUs need relatively high mounting pressure to maintain a secure connection to the motherboard - could an ultra-thin IHS vapor chamber withstand this kind of pressure over time without buckling?
What do you think?
What do you think?
