I find it difficult to read text on monitors. The grid really bothers me.Originally posted by: AmdInside
I don't know much about this subject but unless you do a lot of printing professionally, is there really a need for one?
Originally posted by: Chaotic42
I know there are a few very expensive monitors out there that do more than 96DPI, but will the mainstream displays ever get better? Does anyone have one of these displays? Are they really worth the money?
DPI is fixed. My monitor does 1920x1200 and is 20" across. There's no way to change the actual pixels in the monitor.Originally posted by: astroidea
Most CRTs easily does greater than 96dpi.
Originally posted by: SonicIce
How exactly do you measure DPI on a monitor?
Originally posted by: Griswold
If you want higher DPI, you need higher resolutions on less screen real estate - and who really wants that?
Absolutely. Not only would I like it for work, but it would make gaming even better. Of course, nVidia and ATI would have to get in gear.Originally posted by: SonicIce
i think the goal is more pixels in the same amound of space for a more detailed image.
What for? More is not always better. If you read alot, lower DPI is often better for Joe Average simply due to the font size it produces.
113? Across is not the same as diagonal. 1920/20 = 96. If CRTs had no maximum DPI, you could set them to whatever you want. There has to be some limit.Originally posted by: astroidea
DPI is fixed on an LCD, not a CRT.
A CRT's DPI depends on whatever resolution you set it to be.
According to the calculator nullpointerus linked, the DPI of your screen at 1920x1200 is 113dpi.
Originally posted by: zephyrprime
Eventually, sure. I'm sure we'll have 300dpi monitors or whatever. But the problem is font sizes and image scaling. Even if windows or Osx or linux or whatever handles these issues alright by itself, individual applications usually ignore this issue. The entire industry will have to plan for increased dpi years before it actually is implemented in hardware and legacy apps will have to scaled by the OS.
