Will upgrading the body (D5100) help with video autofocus?
nexus5rocks
413
84
101
It's well chronicled that Nikon (and of that vintage) are not great at video.
The kit is a D5100 with either 18-200mm or 35mm shooting at f3.5, 1/60s and 1600 ISO and it is constantly "hunting", often times failing, or extremely slow when not failing.
Will a newer body like a d5500 help, or even stepping up to a d7500?
Or are the lenses a limiting factor as well?
Or do I need to abandon the Nikon ecosystem and go to Canon?
jtvang125
5,399
51
Won't help. Even Nikon's latest d850 didn't improve video AF much if at all. Until they implement some type of on-sensor focusing tech like Dual-Pixel AF on Canon or Hybrid AF on Sony then the video AF is going to remain poor.
nexus5rocks
413
84
101
Ok, when that happens (apparently they have a patent for a quad pixel AF), will my current lenses be "compatible" with it?
The pixel tech is on the body sensor, so I imagine it would, right?
turtile
633
315
What exactly are you trying to do with the video? There's a lot of issues with using auto modes in video which is why the professionals usually use manual focus. DSLRs are even worse because the aperture change makes noise along with the focus motor. (you can buy de-clicked manual aperture lenses but they are really expensive)
Rifter
751
Its way way cheaper to just use an external mic to overcome this issue.
nexus5rocks
413
84
101
Bought a Zhiyun Crane and trying to get some smooth video out of my D5100 mounted on it. Being on a gimbal, it's not easy to use the focus ring.
AF sound isn't going to be an issue most of the times I'll edit an audio track in. For the times I need the live sound, a mic will be used.
Yes, I'm probably not using the right tool (Nikon DSLR) for the job (taking video).
turtile
633
315
The larger sensor cameras are always going to have more trouble autofocusing since the circle of confusion is going to be much smaller. Nikon isn't as good as the others because they aren't producing video cameras like Sony and Canon - they have to work around or license patents. The video quality is really great for the price since you can use a large high resolution lens though so I only like using it for recording things that aren't too difficult.
jtvang125
5,399
51
For gimbal work you'll want something with good and fast AF. But you can get around that by using a wide angle lens and using a smaller aperture for a deeper DOF. That way just about everything is in focus.
