Will this work for SW:TOR? How Well?
sammyt555
9
Processor: AMD Pheonom II Six Core 1100T 3.3ghz
Ram: 8gigs of DDR3 Duel Channel Kingston Blue/HyperX Gaming Ram
Sound Card: Asus Xonar DG Premium Sound Card
Graphics Card: ATI Radeon HD 6870 w/ 1gig DDR5
Motherboard: Gigabyte GA-870A-UD3 Motherboard (AMD 870 chipset w/ sata3 and usb3)
Hard Drive: 500gb Sata3 6gb/s 16mb Cache 7200rpm
DVD Drive: CD/DVD RW drive 24x
Case: Apevia Cruiser-X Midtower (Black)
Power Supply: 700watt XtremeGear SLI/Crossfire Ready
Operating System: Windows 7 64bit
How do you guys think this will work? i am pretty close to placing a bid on it, 6 core 8 gig ram and 1 gig video card just seems sweet.
extras:
Logitech Wireless Keyboard and Mouse
Batteries for the keyboard and mouse
2.0 Altec Lansing speaker system
Professional Gaming Headset by Fatal1ty
An Asus Full HD 21.5" Slim Gaming LCD Monitor
All the cables needed
Free Modern Warfare 2 Video Game
Recovery Media
High Quality APC Surge Protector w/ cable protection
anything jump out as a red flag? incompatible parts?
What do you guys think about settings? Full high or med?
How long do you guys think i will be able to game well with this pc?
thanks for any information, total nub here.
Please don't yell.
-Thanks
ViRGE
mfenn
22,400
www.mfenn.com
Font size much?
I haven't seen any TOR benchmarks, so I can't say for sure. Odds are it will be fine, but we just don't know at this point.
That being said, I wouldn't buy that system unless I was getting it for a song.
DaveSimmons
40,730
670
Right, it depends on your budget. If it's very tight, then an AMD CPU gaming system is OK (but why 6-core? The extra two won't help).
For medium and higher budgets the intel i5 processors make more sense.
aphelion02
699
TOR minimum requirements:
OSWindows XP, Vista/7 CPUAMD Athlon 64 X2 Dual-Core 4000+ or better · Intel Core 2 Duo Processor 2.0GHz or better
RAMWindows XP: 1.5GB
Windows Vista and Windows 7: 2GB ·
PCs using a built-in graphical chipset, 2GB RAM recommended. VideoATI X1800 or better* · nVidia 7800 or better* · Intel 4100 Integrated Graphics or better*
DVD-ROM8x or better *Minimum of 256MB of on-board RAM and Shader 3.0 or better support.
You will be fine many times over. That said, that system will most likely be pretty bad performance / cost. You are getting fooled by the numbers.
oynaz
2,449
That depends on the cost. I have seen some very good offers on AMD systems.
aphelion02
699
Judging from the way he phrased his post, emphasizing the core count and video ram, its very likely he doesn't know enough to tell a good deal from bad.
