- Dec 29, 2000
- 898
- 0
- 0
MPIO-DGM MP3 playerMP3 player
spec:
CUSTOMER SPECIFICATION
For DMG128
Oct 10, 2001
Digitalway Co.,Ltd.
APPROVED BY CHECKED BY
SAFETY APPROVALS
FCC
- Electromagnetic Compatibility Emission : United States Standard 47 CFR Part 15, Subpart B (Tested at BABT Product Service INC located in Santa Clara CA 95054 USA)
EU Declaration of Conformity (CE)
- Low Voltage Directives : 73/23/EEC and 93/68/EEC
- Electromagnetic Compatibility Directives : 89/336/EEC, 92/31/EEC and 93/68/EEC (EN 55022:1998 Class B, EN 55024:1998)
General Performance
- Size : 67.7(W) x 67.7(H) x 18.5(D) mm
- Weight : 63.5 g (without Battery)
- Decoding Format : MPEG-1 Layer III, MPEG-2 Layer III, MPEG-2.5, WMA Version 7 and WMA Version 8
- Support ID3 Tag Version 1, Version 2 for MP3 file
- LCD : 128 x 48 Dot Matrix Graphics LCD with Blue Color EL Backlight
- Power Consumption : 130 mW (44.1KHz, 128Kbps, Joint Stereo MP3 File)
- Support seven (7) Languages on the LCD for Menu, Filename and Contents Information with Unicode Font
- Output Level : 14 mW (7 mW for Left Channel and 7mW for Right Channel at Maximul Volume Level)
- Output Impedance : 16 Ohm
- EL Backlight Brightness : 40 cd/m2 (70Vrms/300Hz)
- Signal To Noise Ratio : 90dB (with filter)
- Total Harmonic Distortion : Less than 0.1%
- Battery : ?AA? Size Alkaline Battery
- Battery life time : Max 18 hours
- OS : Windows 98, Windows ME and Windows 2000, Mac (ver 8.6~9.1)
- Internal Flash Memory : 128MB nand type memory
à Total 126 files can be stored if it follows 8.3 DOS filename convention
( 125 files can be stored in case ?memo.mem? file is stored on the memory)
- Smart Media Card : 8/16/32/64/128 MB with SSFDC Format
- Voice Recording : G.721ADPCM (32Kbps)
à Minimum Required Recording time : 5 sec.
- Firmware version : 02.10
- MPIO manager version : 2.2.0.0
DETAIL PERFORMANCE SPECIFICATION
Processor
- ARM7TDMI core working at 74MHz (Cirrus Logic?s EP7209)
- Package Type : 208 Pin BGA
- 87mW power consumption on normal MP3 file (44.1KHz, 128Kbps) decoding
- 8 KB 4-Way Set-Associative Cache
- MMU with 64-Entry TLB
- Write Buffer
USB
- Fully Compliant with USB 1.1 Specification
- Maximum Transfer Speed : 4.2 Mbps
LCD Module
- 128 x 48 Dots Matrix LCD Module
- Display Mode : Black and White
- Display Type : Positive, Transflective
- Duty Ratio : 1/49
- Bias Ratio : 1/8
- Viewing Direction : 6 O?clock
- Dot Arrangement : 128 x 48 dots
- Module Size : 35(W) x 49.7(H) x 1.8 (D) mm
- View Area : 32(W) x 24.5(H) mm
- Active Area : 24.305(W) x 22(H) mm
- Dot Size : 0.175(W) x 0.195(H) mm
- Dot Pitch : 0.19(W) x 0.21(H) mm
- Weight : Approximately 8g
Electroluminescent (EL) Backlight
- Light Area : 31.0(W) x 25.1(H) mm
- Dimension : 34.5(W) x 27.5(H) mm
- Thickness : 0.45 mm
- Brightness : 40 cd/m2 (70Vrms/300Hz)
- Half Life : 5,000 hours
- Pin Gap : 4.00 mm
- Lighting Color : Blue
Equalizer
- For the equalizer mode, the center frequencies of the bass and treble are 200 Hz and 3 KHz. Each of the equalizer modes are controlled by the bass treble configuration.
EQ mode Bass : 200 Hz ( Center Frequency) Treble : 3 KHz ( Center Frequency)
Normal + 0 dB + 0 dB
Pop + 3 dB + 9 dB
Rock + 5 dB + 6 dB
Classic + 0 dB + 4 dB
User + 1 dB by 1 point up + 1 dB by 1 point up
- For the 3D sound mode, DMG adopted Q sound Lab?s Q2X 3D sound algorithm which was developed for the digital sound.
Repeat
- Normal, Repeat one, Repeat all, shuffle, intro
Erase
- Erase all, Erase file
System Mode
- Backlight : Never, default(3 sec), user( 3~30 sec)
- Autoplay : Enable, Disable
- Display title : File name, Tag info
- Scroll width : default (16 pixel/sec), User ( 16, 32, 48, 64, 80, 96, 112, 128 pixel/ sec)
Memopad
- 1 memo file can contain up to 32 Sub-memo storage (a kind of directory)
- 1 memo file size is about 16kbytes(16,384bytes) and 1 Sub-memo storage size is 512bytes
- It (memo.mem) will be deleted by selecting ?Erase all? or ?Erase file? in the player
- Each Sub-memo cannot be deleted independently in the player.
Headphone Output
- Impedance : 16 ohm
- Output : 7 mW for each of the channel
- Frequency : 20 - 20,000 Hz
Earphone
- Type : Open Air Dynamic
- Drive : 14.8 mm
- Sensitivity : 95dB
- Plug : 3.5mm, Gold coated stereo 3 ways plug
- Maximum Input Power : 50mW
- Normal Input Power : 10mW
- Cord Length : 120cm
ENVIRONMENTAL SPECIFICATION
Temperature
- Operating : -10 °C ~ 50 °C
- Storage : -25 °C ~ 55 °C
Humidity (Relative)
- Operating : 20 % ~ 80 %
- Storage : 10 % ~ 90 %
Vibration (Non-Operating)
- Frequencies between 10-50 Hz at 2.0 G maximum for 30 minutes duration for each X, Y and Z axis
- Sweep Time : 5 min
Packaged Unit Drop
- Shall not sustain any damages when exposed to one drop of 100 cm each onto one corner, three adjacent edges, and six surfaces of the package
RELIABILITY AND SERVICEABILITY
Mean Time Between Failure ( MTBF )
The calculated MTBF shall not be less than 20,000 hours of Continuous operation at 25°C. The calculation shall not include LCD, EL backlight, and Key button.
Rate Of No Rejected Goods
: 95 % ( statistics from the initial production : 25/500)
PACKAGE
Box
- Paper : (Recycled paper 80%)
Outer layer paper -- SC 240g,
Middle layer paper -- S 120g
Inner layer paper -- SK 170g
Accessories
- USB data cable
- Installation CD
- Musicmatch jukebox
- User?s guide
- Document of warranty
- Eeaphone
- Strap
- Carrying bag
will it work with kington cf memory card from dell? Kington compact memory card
thank you
spec:
For DMG128
Oct 10, 2001
Digitalway Co.,Ltd.
SAFETY APPROVALS
FCC
General Performance
Processor
- Write Buffer
USB
LCD Module
- Duty Ratio : 1/49
- Bias Ratio : 1/8
- Pin Gap : 4.00 mm
Equalizer
Pop + 3 dB + 9 dB
Rock + 5 dB + 6 dB
Repeat
Erase
System Mode
Memopad
Headphone Output
Earphone
- Drive : 14.8 mm
Temperature
Humidity (Relative)
Packaged Unit Drop
PACKAGE
Box
Accessories
- USB data cable
- Installation CD
- User?s guide
- Eeaphone
- Strap
- Carrying bag
thank you
