- Jul 21, 2023
- 6
- 0
- 11
i have silverstone gd10b case according to its manual its measurements are:
"Limitation of expansion : Compatible up to 12.2" (309mm) long, width restriction-5.25" (133mm)"
"Dimension 442mm (W) x 171mm (H) x 362mm (D), 27.4 liters
17.4" (W) x 6.73" (H) x 14.25" (D), 27.4 liters"
gpu dimensions: 260X135X43mm for my favorite card is
SAPPHIRE NITRO+ RX 580 8GB GDDR5 but if you suggest another rx580 brand its OK.
definitely it installable but what about heat? and cable management? , will it fit comfortably? i have 550 power supply do you suggest other GPU brands , or any suggestion to improve my system like cable management
i dont have other cards on my systems.
My system amd fX 6300, MB MSI 970gaming series, RAM gskill 16GB. my power supply is evga super Nova 550 g2 , Samsung ssd 500, hd 1terabyte. my os is Ubuntu
thanks in advance
thanks in advance
