will this ram work with my system?
theAnimal
3,828
23
Your mobo will not do triple channel, so you should be looking at a kit with 2 or 4 sticks of RAM.
llmercll
705
so if i put 3x2gb in it wouldn't work?
would the ram work at all? even if it isn't triple channel?
llmercll
705
thanks for the help so far! I understand it will work as dual channel instead of triple, which isn't bad because I'd be using dual channel anyway.
But I'm concerned about is the whole "made for i7" "xmp" stuff. I don't know if it's compatible with amd systems because of the "specific" marketing.
theAnimal
3,828
23
The best thing to do is go to your mobo manufacturer's website & check their list of compatible RAM.
Blain
Don't worry about marketing hype like "Gaming Memory", etc...
Go for DDR3 that's rated for operation at 1.5v or lower.
Here you go
