corky-g, what makes you say that this is a type II card? Transcends website does not specify and it looks like a type I card from a cursory glance. If this is the case, then the Kodak DC-4800 should not have a problem reading it(Generally larger CF cards will work with older cameras fine with the only common stipulation being that you can't go over 1GB due to File System limitations).
