Will Thermalright HR-05 Fit on S3 motherboard with Arctic Cooler Freezer 7 Pro?
eojinlim
288
I know I need to buy a northbridge chipset heatsink but unsure whether the Thermalright HR-05 will fit beside my cpu hsf.
tallman45
1,463
The HR-05-SLI would be a better option, it is offset and may end up fitting better
eojinlim
288
It's a rather dumb question but would SLI fit on a non SLI board? Or wasa it just labelled that way to explicitly say that it's compatible with all boards INCLUDING the SLI ones?
Shimmishim
7,504
yes.
it should fit fine.
the "sli" is just a way of saying that it's off settable to allow for non-interference when you run cards in sli.
Markfw
May 16, 2002
27,196
16,092
You are now up to 6 threads about the same issue, your overclock, and how to fix it. I am not giving any more assistance until you can learn to STICK WITH ONE THREAD.
eojinlim
288
-_-, this isn't about overclocking. I've already overclocked successfully, if you read my previous posts.
Settle down.
