it fits the asus without any mods, but you have to trim the clip to fit the abit and the mounting bracket pushes the capacitors a bit, but you can always switch em around.
I measured out the spacing on my A7N8X and Sonata and I only have 52mm clearance from the PSU. Not the needed 55mm as stated on the Zalman website. So I took the safe road and got a Silent Boost.
from the looks of the heatsink, it will fit on the NF2 DFI LP. It will take an SLK-900A also. If you are definitely interested in knowing for sure, I will ask the labs to make sure =)
