UsandThem
- May 4, 2000
- 16,068
- 7,383
- 146
Oh, one last questions before I buy:
Since I'm keeping my SSD which has my OS on it, do I:
1) Need to reinstall windows? Or is it just plug and play new CPU/mobo/ram.
2) If 1 is true, can I use the same product key since it's the same drive?
Windows 10 is a better at that sort of thing, but doing a "reset this PC" in Windows 10 would probably be a good idea.
Most likely after you boot up with your new hardware, you will need to reactivate Windows. When you try to activate it online, it will probably fail. You will probably have to call them, and if you have an OEM license, they might not let you activate it as it is tied to the motherboard. Only way to know for sure is to call them when prompted to.
