just built a computer, had it up and running installing winxp, then crashes with a blue screen...
restart it, doesn't start back up...turn it off, then on, same thing...clear CMOS, restart, it shows the video card bios, then stops...anything after that and the PSU won't even spin up.
this is what i've tried:
1) removed the mobo from the case and had it sitting on cardboard (no metal touching it)...only the CPU and memory installed - nothing.
2) tried the PSU on another mainboard, as well as the power switch from the same case on a different mobo, and it successfully booted the other mobo...this rules out the PSU and the case's power switch
3) swapped out the memory for mem that i know works (i'm posting from this from the machine w/ the working mem.)...nothing....this rules out memory
4) the video card and nothing else is even installed, so everything but the CPU and mobo are ruled out.
so what I'm wondering is, say I was to take the cpu out, and keep just the memory in, if the mobo was working, would it power up the PSU and give me some error beeps?
