Will the G450 PCI work with my ASUS P3v4x mobo?
Wirehead
184
I bought the Marvel G450 eTV a couple of weeks ago and now was ready to buy the G450 PCI until I saw the following message on the Q&A at the Matrox site:
Does the G450 PCI support bus-mastering for non-Intel chipsets? (top)
For non-Intel chipsets, the G450 PCI does not support bus-mastering. While this lowers performance on synthetic benchmarks, it does not hinder the everyday usability of the card. Additionally, for the combination of G450 PCI and non-Intel chipsets, Open-GL acceleration and DVDMax are not supported.
Matrox has identified certain instabilities when bus-mastering is activated on the combination of non-Intel chipset and the PCI version of the Millennium G450 series (model number G45+MDHP16DB).
My mobo has the VIA chipsets instead of Intel's. Since bus-mastering will not work, will I be able to use the dualhead feature on this card? Will Win98SE allow me to use the multi monitor feature if the card does not have bus-mastering? I do not play games so the Open-GL is probably not too inportant to me. Even though it will not support DVD Max, I believe that I can get it through my G450 eTV card. I have not tried it yet because I do not have a DVD-ROM. Thanks for the help.
