So I just upgraded to a Kingston HyperX SSD drive, using the Acronis "clone" technique as instructed in the manual that came with the SSD. I've since read that the best way would have been to install Win7 fresh on the SSD in AHCI mode, but at this point that's neither here nor there. :$ I followed Kingston's instructions and I guess it's working fine... but I'm in IDE mode.
Now I have Win7 running on the SSD, but I also have a second hard drive with all my "stuff" on it... it's a standard SATA II, 7200RPM drive. Both hard drives (and both of my DVD drives) are all four on the same SATA controller (AMD SB750)... I also have two GSATA (Gigabyte SATA) ports but didn't really want to use them as I've read mixed reviews and have had zero problems on the AMD ports + drivers.
So if I switch to AHCI after Win7 installation, using the reg edit as detailed here, and then rebooting and changing the AMD SB750 SATA ports to AHCI... that will change both hard drives to AHCI, correct? Is that all okay, to have my SSD and standard SATA2 on the same controller in AHCI mode? I just want to make sure I don't mess anything up. Thanks!
