- Mar 11, 2000
- 24,003
- 1,622
- 126
I have a Firewire hub which didn't have a power adapter and but my other Firewire hub's adapter fit it and I stupidly plugged it in. I found out later that the second hub uses a 12V power source, but the first hub is only supposed to use a 5V power source. (I stoopidly figured 12V was gonna be OK, since Firewire is supposed to be able to provide 12V x 1.25A ideally. In fact, my other hub is rated for 12V x 1.5A.)
With the 12V adapter, the hub power light comes on normally, but the hub wouldn't provide power to anything. There is a separate light for Firewire power, and it doesn't come on. Now I've tried a 6V adapter and power light still comes on (but the Firewire light does not), but the hub still won't provide power to anything.
The hub works fine if I provide power though a powered 6-pin Firewire cable plugged into it. Both the Firewire power light and the hub power light come on.
Could I have fried it? I would have thought that if I fried it, it wouldn't work at all, or else at least I wouldn't be able to get power at all, even from a powered Firewire cable. Nothing on the board looks fried.
ie:
12V DC:
Hub power light on
Firewire light off
No power to Firewire devices
6V DC:
Hub power light on
Firewire light off
Powered 6-pin Firewire cable which I think is 12V:
Hub power light on
Firewire light on
Power to Firewire devices
ie:
12V DC:
Hub power light on
Firewire light off
6V DC:
Hub power light on
Firewire light off
Hub power light on
Firewire light on
