Will socket A heatsinks fit on a socket 370.
Link19
971
I have seen many heatsinks that state being compatible with all socket A and socket 370 CPUs. Are they all cross compatible with both sockets. For instance, I found a Thermalright ALX-800 heat sink that says it's socket A compatible, but says nothing about socket 370 compatibility. It is sold at an exceelent price at this website:
http://www.crazypc.com/Merchan...amp;Product_Code=50983
Will this heasink fit a socket 370 CPU? It looks like it is an excellent heatsink being sold without a fan? I assume this would be more than enough to run a socket 370 Celeron or Pentium III fanless while keeping it cool? Would this heatsink alone be enoug cooling assuming it will fit socket 370?
sharkeeper
10,886
Be wary of spring tension! If your CPU doesn't have an integrated heatspreader, excessive force will easily send your core crying it its concoidal oblivious mercy. OTOH, too little force can cause it to overheat.
Cheers!
Link19
971
Originally posted by: MDE
It'll fit but I don't think you'll be able to run fanless.
I wouldn't be able to run fanless? I thought this heatsink was one of the best and it was meant for AMD CPUs which run a lot hotter than Intel CPUs and it doesn't even come with a fan by itself. So if this heatsink wouldn't let me run fanless, then what heatsink would? I'm planning to use Artic Silver 5 thermal compund to help as much as possible.
MDE
13,199
You'll need some airflow to cool the thing off, even if it's a quiet Panaflo fan at 5V or something similar. You could also rig up a fan duct and use a case fan to pull air over the heatsink and exhaust it directly.
Link19
971
If I underclock a Pentium III, would I be able to run it fanless then? Is this heatsink really as good as it seems?
MDE
13,199
Honestly I don't know, I've never had the opportunity to fiddle with a PIII, so you'll have to ask someone else who knows a bit more.
Link19
971
What's the best heatsink material for cooling in general? Is it pure copper, or a copper base with aluminum fins?
splice
1,275
I run a 1GHz Celeron fanless using a Thermalright AX-7 in a slim AOpen case. There is only one fan in the whole system, which sits in the power supply.
This Case
Link19
971
Originally posted by: MercenaryForHire
To the original question - Yes, but S370 will not work on Socket A.
- M4H
Who's original question were you answering? Mine? WHat is the S370 heatsink? I want it to work on a socket 370 ZIFF, not socket A. But socket A and socket 370 both use the same connectors so their heatsinks are cross compatible.
WobbleWobble
4,867
You might be able to get away with it fanless. I've run a couple systems with fanless P2/P3 CPUs and their Celeron based counter parts. Many OEM systems were also fanless with those processors as well. Try it, the worst that can happen is having your computer freeze.
Mik3y
Banned
Mar 2, 2004
7,089
not true taht amd cpu's run a lot hotter then intel cpus. you've got it mixed backwards. :D
Jan 31, 2002
40,819
- M4H
Yours. S370 = Socket 370.
You can use a Socket A (AMD) heatsink on a Socket 370 (Intel) processor.
You cannot use a Socket 370 (Intel) heatsink on a Socket A (AMD) processor. The "Intel" heatsinks do not have the "raised edge" neccessary to fit properly onto a Socket A board, and will not make contact with the core. Your chip will burn to a crisp. :p
- M4H
Jan 31, 2002
40,819
Old AMDs ran hotter than old Intels. TBirds were little pockets of Hell in a silicon core. :D
Reverse the relation for newer chips (AXP Barton, A64) vs (Celeron-D, Prescott)
- M4H
CraigRT
31,440
If you want to run fanless you need a heatsink that has more spaced out cooling fins... they are so close together because it's designed to have air actively flowing through it.
you need a larget HSF with more space between the fins to dissipate the heat more efficiently.
I don't have any recommendations though.
Link19
971
Would the Zalman CNPS3100P flower heatsink be big enough and have fins spaced out far enough to run fanless for a socket 370 CPU? There is a picture of it here:
http://www.sharkacorp.com/Merc...mp;Category_Code=sock7
