A. Cosmic Rays: If a cosmic ray were capable of interacting with the tiny traces in a CPU, how would it make it through the computer case? Or your house?
B. Electromigration: They won't sell you the CPU unless it can be made reliable.
My buddy just bought a netbook and didn't like the os load times, so he left it running 24/7 .... the book was dead within two weeks of him making that decision.
I'd say the new tech has a ways to go when it comes to reliability, the ones I've worked with all run hot.
The 1802s used in space are built using Silicon-on-Sapphire which is much more stable in a radiation environment
On this website you will find some information about cpu's used in space.
http://www.cpushack.net/space-craft-cpu.html
The RCA 1802 from the voyager 1 and 2 :
I do not know how they do it, but BAE systems hardens their processors against radiation. Anybody has any more detailed information on that ?
I found this.
http://en.wikipedia.org/wiki/IBM_RAD6000
I found something, but more information is always welcome...
http://en.wikipedia.org/wiki/Radiation_hardening
Found some more detailed information.
http://www.mse.vt.edu/faculty/hendricks/mse4206/projects97/group02/space.htm
http://www.mse.vt.edu/faculty/hendricks/mse4206/projects97/group02/hardening.htm#soi
Redundancy also works. If you have three of something working in parallel and then vote best 2 out of 3.
I know chip makers love die shrinks because it lets them get more yield
Apparently DRAM is most effected by it because each bit is essentially a tiny capacitor, so intercepting some cosmic energy can cause it to flip state.
This has its own problems. What if it is the voting mechanism that fails?
Just wanted to point out that yield in the fabrication business is a specific term referring to the proportion of "good" devices on a wafer (as in, devices with no defects). Hence, yield tends to go down when moving to a new process, then gradually climbs as the process is refined. The device density increases with process shrinks, so you get more devices per wafer, but yield doesn't go up.
