Will set DDR3L memory speed rise up to maximum limit shorten its lifetime ?
Discussion in 'Memory and Storage' started by abdulbadii, Dec 3, 2017.
  1. abdulbadii
    abdulbadii Junior Member
    Aug 10, 2017
    11
    Will set DDR3 or DDR3L memory speed rise up to maximum limit shorten its lifetime ?
    If the memory age is 5 years old since the fabrication with normal and good usage over time till now and is to be set up to 1600 MHz max speed limit, how many more years it'll last in the future ?
  2. Loading...
    Similar Threads - DDR3L memory speed Forum Date
    How can I determine memory DDR3 or DDR3L low voltage with cpuz tool Memory and Storage Nov 24, 2017
    DDR3L and DDR3 question Memory and Storage May 12, 2017
    G.Skill ECO may be considered as being DDR3L RAM? Memory and Storage Oct 13, 2016
    same DDR3L in x58 and z170 Memory and Storage Feb 25, 2016
    DDR3 DDR3L and LPDDR3, make sure you get the right memory for your computers Memory and Storage Sep 29, 2014
  3. UsandThem
    UsandThem Super Moderator
    May 4, 2000
    7,461
    478
    There is no way anybody can guess when your RAM will die. Most RAM comes with a lifetime warranty, so odds are you be on to a new computer, and DDR3 will be obsolete long before the RAM ever fails. RAM is rated to run constantly at its stated speed.
    #2 UsandThem, Dec 3, 2017
  4. WhoBeDaPlaya
    WhoBeDaPlaya Diamond Member
    Sep 15, 2000
    7,300
    368
    I wouldn't worry about it at all. Hell, I'm still using 1.65V DDR3-1600 sticks from my Nehalem builds in various systems
    (Sandy, Ivy, FX, Phenom II), and they still past memtest86+ with flying colors.
