SCSI drives normally rotate at higher speeds (15k right now, most drives still being at 10k), SCSI supports drive to drive transfers without bothering the CPU.
For a desktop, there is rarely a reason for SCSI. For a server, there are many pro SCSI
ACTUALLY, scsi is now moving to 640 on PCI-X v2. Ultra320 has been out for quite some time, but only in server markets.
What is really interesting is the fact that SCSI is moving to Serial. :Q THis must be weird to hear, but the amount that corporations spend on scsi-based software enviroments would be too great a loss.
Instead of abandoing SCSI, the interface will just run over serial hardware. Even Serverworks, the king of server chipsets, is rolling out pci-x v2 on their mobos. Appearntly the future looks bright for scsi. The protocols are what really make it shine. I can't wait to try a ultra 640 or Ultra1280 SCSI setup @ 30k rpm WOOHOO!!
In addition, people like yourself have to realize the prime advantages of SCSI.
The interface is ideal for rapid and simul;taneous transfers. Take my Quantum Atlas 10kII Ultra160 HD.
For sustained rates, it gets about 38MB/s, not stellar, but by no means great. It "appearntly" gets its a*s whooped by ide RAID systems in Sandra's benchmarks.
Then check out the access times. Flat out 5-6ms. I guarentee you any, and I mean ANY IDE drive will have slower Acesstimes. It is only 18GB, but since it is quick at acessing a lot of different data streams, it is ideal as the OS/Program files drive.
SCSI isn't going anywhere.....it's just THAT good.
..the fact that the Seagate 36LP's tranfer at a sustained rate of 70MB/s and have 3.6-3.9ms access times doesn't hurt either.
