mother board : http://www.newegg.com/Product/Product.asp?item=N82E16813131070
ram : http://www.newegg.com/Product/Product.asp?item=N82E16820145590
Ok on my mother board it says
Number of DDR2 Slots 4x 240pin DDR2
DDR2 Standard DDR2 800
Maximum Memory Supported 8GB
Dual Channel Supported Yes
Notice: Only DDR2-800 memory supporting JEDEC approved 1.8V operation with timings of 5-5-5 or 6-6-6 is supported on Intel Desktop Boards based on Intel 965 Express Chipsets.
This is my ram
Brand CORSAIR
Series XMS2
Model TWIN2X2048-6400
Type 240-Pin DDR2 SDRAM
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-12
Voltage 1.9V
ECC No
Buffered/Registered Unbuffered
Heat Spreader Yes
This is my ram
Brand CORSAIR
Series XMS2
Cas Latency 5
Timing 5-5-5-12
Voltage 1.9V
ECC No
Heat Spreader Yes
