Will PCPC silencer 750 fit in P182?
yikes... it will be close.
im assuming these because my brother has a p180. We had problems mounting a silverstone zeus 700 watter in it becuase it was too long.
You might need to get rid of that middle lower section fan to fit it. However i think the P182 underwent some cable mods. So you might just need to route it off the side.
also i have the silencer 750 quad sli.
And it was about as long as my brothers zeus.
This is the dimensions of the PCP&C : 5.9? x 3.4? x 7.1? (W x H x D).
And here is the dimensions of a Seasonic S12 (W x H x D): 5.9 x 3.4 x 5.5.
So its up to you to decide if it will fit. It is 1.6"s longer......
Tyler
anyone able to check their p182 for me if they can fit a 7.1in deep PSU? its about an inch and a half longer than standard PSU's
From eyeballing it, it will fit but not in the PSU cage, also cabling management might be a pain in the ass.
Thats EXACTLY what i said on my second post, But i guess the Op doesnt believe me :T
The only way we were able to fit my brothers silverstone zeus 750, which is almost exactly the same length as my PCnC 750 Silencer Quad. We had to remove the middle fan on the lower cage, and use the HOLE to route the cables. That was the only way to make it work. The cables at the edge wont allow you to mount that fan.
:T
