F friarfraust Member Sep 17, 2004 158 0 0 Sep 17, 2004 #1 The cpu is running with pc 133 ram atm. The motherboard supports ddr 2100, it's an asus a7a 266
Appledrop Platinum Member Aug 25, 2004 2,340 0 0 Sep 17, 2004 #2 yea edit: if the fsb on the cpu is 266/133 then it will be good..
W WobbleWobble Diamond Member Jun 29, 2001 4,867 1 0 Sep 17, 2004 #3 Yes, it'll work with PC2100 memory. However, you can only run either PC133 or PC2100 at once and not both. Doing so may fry your memory chips and your motherboard.
