Will parts on desk work OK?
bbinnard
32
I'm going to be taking all the drives out of my current PC and putting them into a new system who's parts (motherboard, PSU, CPU, RAM, video card, fan) arrived next Tuesday. But the new case doesn't arrive until Friday. So is there any problem with putting the parts together on my desktop and running them outside the case?
vshah
19,003
24
as long as the surface isn't conductive, it should be ok. but beware of static discharges etc.
personally I would just wait
vshah
19,003
24
You won't have a power button to turn them on...
many motherboards have power/reset buttons on the board. or he could just wire up the switches to his old case without actually putting the motherboard inside.
DSF
4,902
Or he could always just use the screwdriver trick.
Edit: Not that I'm necessarily suggesting running it sprawled out on your desk.
ch33zw1z
39,756
20,329
images
See that POWER switch, if you don't have a button, connect the two pins using a screwdriver, problem solved. it only takes a second to turn it on.
I would wait for the new case, but if you just HAVE to boot it up then put everything on some cardboard or a static mat.
sm625
8,172
137
I've run many a guts of PCs on my bench. I never ruined any by doing so.
