Will my car battery die if I leave the trunk open for 12hrs?
JEDI
29,391
2,738
2005 Mazda3
I carpooled to work today. I first grabbed something from the trunk of my car, then exited my garage. I was in a rush, and didnt realize i didnt close the trunk till i got to work.
Will leaving the trunk light on for 12hrs kill the battery?
PhoKingGuy
4,685
It will probably turn them off by itself after an amount of time. I left my Jettas interior lights on last night and they were off this morning and it started up fine.
JEDI
29,391
2,738
yeah, thats the interior lites. mine does the same thing.
but is the trunk lite on that same circuit?
possibly, though you never know.
I've found modern cars will shutdown the circuit if the battery drops below a certain voltage, enough for it to give it one rescue start.
I've never completely depleted the battery in my car(s).
Zap
22,377
7
This happened to my wife's Mazda 3, but the trunk was left open over a weekend in our garage. Come Monday morning it needed a jump start.
obamanation
Banned
Mar 22, 2010
265
It won't "kill" the battery per-se but you definitely should get a battery re-charger and charge that sucker because your car's alternator won't be able to do it. The car's alternator is a battery maintainer, not a charger.
LTC8K6
28,520
1,575
If you have a Battery Saver circuit, then most likely the trunk light will be turned off after 30-45 minutes. If you don't, it will most likely discharge your battery to where the car will not start.
T2urtle
3,432
it should die, my friends new 09 mazda 3, he left for vegas for 4 days came back no start. same idea if you leave the light on since you have something drawing the battery, and my friend had nothing.
if it did just jump it and leave it on for about an hour to charge up the battery and you should be good to go. Dont worry too much about it.
LTC8K6
28,520
1,575
Many modern cars have what is called an IOD fuse that is to be pulled for storage. Ignition Off Draw. This gets rid of most of the parasitic draw from the battery.
Just remember to install it again.
LTC8K6
28,520
1,575
4 days should not bother the battery at all, unless you have added something that has increased the parasitic draw.
I would be certain something was wrong with my car if it would not start after sitting for just 4 days.
obamanation
Banned
Mar 22, 2010
265
The alternator is not designed to charge a dead battery. It is designed to maintain a good charge on the battery. It can recharge a dead battery, but it is not meant to do this.
Especially not repeatedly.
Even worse, I think people seriously underestimate how quickly those car alternators can charge a depleted car battery. If the battery is at a state of 0% charge (11.8V when there is no load), when using a wall battery charger, if you charge at 2AH, it will take well over 28 hours to charge that car battery. Cranking the engine takes a significant drain on the battery so the only plausible scenario to ever even consider charging that battery to full would be to have several, long highway commutes. Most alternator's peak output is at 2500rpm, a lot of 4 bangers rev at this speed when cruising on the highway but the cars with bigger engines do not, some cruise at as low as 1500rpm which means alternator output is significantly diminished.
I've charged a few cars with a battery charger that were driven regularly yet had only a 25% SOC. Anyway, it's really hard on the alternator to charge a dead battery and it's just better and more reliable to just use a dedicated battery charger ever so often to ensure that the batteries are fully charged. Car batteries like to be constantly charged, otherwise you get sulfation on the lead plates which means reduced capacity. A decent battery charger can be had for around $50.
CraigRT
31,440
That sucks the other MZ3 owners say it will be dead.
My Nissan turns off the interior lights after like 30 mins or something, if a door is open a crack. I don't know about the trunk though.
LTC8K6
28,520
1,575
I have a secondary car that is driven on short trips only most of the time. These trips are less than 5 miles. The battery is typically only at 50-65% soc when I check it after a few weeks of these short trips. Every few weeks, I charge the battery up with a charger, and once a month or so, I drive the car on the highway 40-60 miles.
I guess if you know your battery is low, you could drop a gear or not use overdrive to get the revs up on the highway, if you have one of those engines that are just loafing along when cruising.
BUTCH1
20,433
1,769
The manager @ my local autozone says the #1 reason alt.'s come back is customers installing then jumping the car and trying to let the new alt. charge the batt. Bad idea as it get way too hot trying to accomplish this. OP, a lot of newer cars have a BCM programmed to shut off anything after 15 minutes or so, you might be in luck..
JEDI
29,391
2,738
thx for the replies.
got home. trunk lite was still on.
but car started!
