Will my auto insurance rates go up
Doggiedog
12,780
if I claim a broken windshield on it?
I found a huge crack in the windshield yesterday. Looks like a rock hit it. Prices for windshields are around $300 out of pocket.
Thanks.
Doggiedog
12,780
Originally posted by: oldsmoboat
No deductible on comp?
Ah crap.
Forgot about the deductible.
Just called the stealership and they want $956! Unreal! The auto glass places are all around $300.
TridenT
16,800
45
Ah crap.
You think you could get it online for cheaper? ;) Hehe...
Oct 19, 2000
17,860
4
Thanks.
$300? Had to replace a windshield on a car last year, and it was only $140 installed.
Scouzer
10,358
Thanks.
Wow, that's cheap. Cost $400 on my car.
Doggiedog
12,780
Thanks.
Seriously!
I had to get my Infiniti windshield replaced and it cost me $220. This car is a Scion tC and it's costing more. I can't believe the stealership had the balls to quote me $956.
Gibson486
18,378
It will not make your current rate go up, but it could be grounds for a hike in a future quote if you ever get another insurance company.
Doggiedog
12,780
IC. That's good to know.
Thanks!
Dec 26, 2007
11,782
Depends on your coverage.
Most of the big insurance companies include glass repair for something like $50 deductible, but not all. Other times it's part of your comp coverage. Other times it's free (usually if they repair the window and don't replace it).
It really depends on your policy. Without looking at it, I can't tell you if it is covered or not (and if it is what coverage it's using).
To answer the OP:
If you don't have any kind of coverage for it, then no it won't affect rates
If you have to file it under comp, then no it shouldn't affect rates (comp claims *generally* don't affect your rates, but can in certain situations and states)
If you have glass coverage, then no it shouldn't affect rates (once again unless certain circumstances, but generally it won't)
Best advice I can give you, is to call your agent and ask about glass coverage on your policy. They should be able to tell you what your policy covers.
olds
50,126
780
To answer the OP:
True.
We had AAA. $50 deductable and the glass companies waive it.
Now we have USAA and the deductable for comp is $500.
jlee
48,518
223
To answer the OP:
True.
They don't have a separate clause for auto glass?
olds
50,126
780
To answer the OP:
True.
Nope.
God Mode
2,903
Thanks.
Seriously!
I bet the stealership outsources their window work to other shops. $656 profit for almost nothing. :)
rudeguy
47,351
14
61
To answer the OP:
True.
Nope.
Mine just changed too :(
I had never had to pay anything out of pocket for glass. Now its the full deduct...
To the OP:
If you tell the glass places that you are paying out of pocket and its not insurance, their rates go down quite a bit.
Gibson486
18,378
Thanks.
Seriously!
LOL...I tried bringing my car to the dealer when my windshield cracked. I said they should fix it because it was under warrenty (only had 12K at the time) and it cracked to due to weather elements and not rocks. The crack started under the frame, so it was not due to me. They just said, "no, but it will only cost you $700 to fix that". It cost me nothing in end through insurance...except when I switched insurance. It came up as a claim, so they added $60 total to my policy. Better than paying $700,
