Will multiple WiFi dongles increase my speed?
TheSiege
3,918
14
I am wondering if I use 3 USB wifi dongles if my speeds would increase. I ask because I have a shop in my back yard and I only get about 2 bars so netflix buffers every once in awhile, but I am wondering if I added a couple more dongles if it would increase the speed...
Feb 25, 2011
16,966
1,597
No.
Multiple crappy connections aren't any better than once crappy connection. Worst case, they'd interfere with each other.
But if you're getting lousy signal, a big honking external antenna will probably help. If your current wifi card doesn't allow external antennae, then yes, you'd need a USB 3 dongle, but it's not the dongle that's helping, it's the antennae.
There are WiFi range extenders designed specifically for outdoor applications. However, I would suggest doing what my friend did - bury a run of sprinkler pipe and run Cat5. :)
azazel1024
901
Your computer is only going to use one of those Wifi adapters at a time anyway.
Bigger antenna is your only choice.
